Bugger asses
Old Jan 24, 2003 | 05:11 AM
kevinragman's Avatar
Bugger asses
Hiya again Im having some good problems with starting my camaro. Last time it ran it started up run for a short while then gave up. Unfortunately, I wasn't here to witness this as my brother -in-law, who owns a custom and american car repair shop called Wacky Racers started it but the afore mentioned problem occured. Since then it has refused to run, until today that is. It ran for aprox' 10 seconds then stopped again. During the time that it ran, it ran really badly, ie; hardly any response from the accelerater, but I checked the fireing order over and over again It now occasionally fires but keeps wetting the plugs. I keep taking them out cleaning them putting them back but the same happens again. I'm very near to giving up now as it is a pain in the *** and it's raining again. Any help again would be greatfully recieved. Cheers.
Old Jan 24, 2003 | 06:53 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Has anyone checked spark?? Sounds like its getting fuel.
You have to deal with wires, coil, distributor, pickup coil, ICM, plugs, wires.
Old Jan 24, 2003 | 01:25 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
If it's wetting the plugs...ie, leaving fuel on them..then they're either not sparking, or doing so very poorly. Severely failing coil? How are your plugwires, cap, and rotor?
Old Jan 24, 2003 | 04:30 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Must be some fouled plugs. My car did that when I took it to the tranny shop after I finaly finished rebuilding my motor. I was barely able to get it to the shop before I couldnt start anymore. I spent a day trying to figure out what was wrong until I pulled a plug and realized it was fouled. Pull your plugs and wire brush them and reinstall and see how your car runs then.
Tas
Dec 23, 2001 10:43 PM
PerthZ28
Dec 19, 2001 09:21 AM
Hype
Dec 4, 2001 05:43 PM
max powers
Theoretical and Street Racing
Nov 17, 2001 06:30 PM
JoelOl75
Mar 19, 2001 06:45 AM
