Sad day...
Old Jan 28, 2003 | 12:37 AM
PeNZ's Avatar
Sad day...
Well about a week ago, the bird took a crap on me, ECU doesnt tell the fuel pump to turn on, tried a new ecu and tried rigging up the fuel pump to turn on when I turn the key, so it was running but then we pulled the batt. wire to hook it up properly and the ecu reset and now it just cranks no start. So in the meant time I baught a 88 Cavalier Z24 2.8 Any suguestions on the bird? A 350 swap is out of the question cuz im in the whole $1500 for the cavy
Old Jan 28, 2003 | 12:50 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
that's a very expensive relay you're driving around in
you sure everything was hooked back up properly & did extencive toubleshooting ?
Old Jan 28, 2003 | 12:56 AM
PeNZ's Avatar
well, I pretty much baught the cavalier for my next car, my fbody was starting to **** me off, and yea all the stuff is hooked up.
Old Jan 28, 2003 | 01:59 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
your oil pressure switch should of turned it on, my fuel pump relay dont work either, but 2-3 cranks of the key and i got oil pressure, and then the pump primes and runs fine. you got oil pressure???
Old Jan 28, 2003 | 07:31 AM
PeNZ's Avatar
hmmm thanks for the tip, ill check that out today when I go look at her
Old Jan 28, 2003 | 08:19 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Few quick questions.
Is your SES light on?
Does the SES light even come on now when you turn the key? You know that 3-4 seconds it comes on to say "hi" I am still working.
Did you check all your fuses under dash?
There are two fuses under the hood that run up the passenger side fender, check those, I think there both 20's.
Old Jan 28, 2003 | 09:22 AM
PeNZ's Avatar
yea ses light works, check all the fuses in the box, but ill check the 2 on the fender today also thanks
David Frans
Oct 31, 2015 08:12 PM
86CamaroDan
Sep 29, 2015 10:08 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
