engine replacement
Old Feb 19, 2003 | 11:27 PM
eddie header's Avatar
engine replacement
well well ive recently aquired a v-6 camaro nothing to rant and rave about but its mine and its an f-body so there well anyway ive bgot a bit of a problem it needs an engine and i was considering just replacing it with the stock 2.8 v-6 and i was wondering if ne1 here has had to do that b4 and if so could u tell me anything about ur replacement that might be helpfull..... thank
1985 chevy camaro 2.8 v-6 5 speed
Old Feb 20, 2003 | 01:18 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: engine replacement
New GM crate motor- HT3.4. Bolts right in- Just use your stock intake and water pump/timing chain cover. Aprox $1800 new. 160 HP- compared to the 2.8 @ 135HP
Old Feb 20, 2003 | 06:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.4l block swap :hail: , then will need 17lb injectors to go with it, much better.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
