How do u remove...
Old Feb 27, 2003 | 06:44 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
How do u remove...
how do u remove the governor out of a 89 RS with a 2.8...andis the 2.8 in my camaro a 2.8 MPFI or something else...ive owned alot of camaros 85 or older and they were....
Old Feb 27, 2003 | 07:06 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
If your V6 is fuel injected and made before 1990, then you have an MPFI 2.8. If it's 90-92, it's an MPFI 3.1. And I believe 82-84 got a carbureted 2.8. The governor....I assume it's programmed into the computer's PROM. You'd have to replace that with a custom one to disable the speed limiter....that's my guess anyways.
Old Feb 27, 2003 | 07:08 PM
Transmission: autos
thats what i though i just wanted to prove to someone thats what it was...oh, i thought hte governor might be somewhere else, anyone know what speed it kicks in at?
Old Feb 27, 2003 | 07:22 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
115 MPH
you can also disconnect your speedo cable
but you obvioulsy wont have a speedo to tell what speed your going
Old Feb 27, 2003 | 07:24 PM
Transmission: autos
i had a 85 that must not have has a governor in it, i wrap the speedo around to like 20....it was a 85 mph speedo though
Old Feb 27, 2003 | 08:13 PM
Nixon1's Avatar
I thought the governor was set at 110? Or was it 115 for the 85 mph speedo cars and 110 for the 110 mph speedo cars?
Old Feb 28, 2003 | 07:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It can vary a bit. I think GM did this to make it harder to find the location within the cal. My '92 was set at 115 off, 112 back on.
The rev limiter is set to 6,212 RPM off, then back on at 5,985 RPM. They are the factory settings.
RBob.
vorteciroc
Jan 2, 2021 07:58 PM
naterman35
Oct 12, 2007 06:55 AM
IROCZman15
Jan 22, 2006 08:21 PM
IROCZman15
Jan 18, 2006 10:23 AM
smithtc
South East Region
Jan 22, 2005 12:14 PM
