TPI Style intake
Old Mar 5, 2003 | 01:49 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
TPI Style intake
I have the same style intake on my car. From the things sadi in this post, it sounds like a good setup. Is it really??? Is there anything other than using K&N Filters that can make it better. I have already taken out those little Elephant ear like thingies that bolt on right under the filters.
https://www.thirdgen.org/techbb2/sho...hreadid=164383
Old Mar 5, 2003 | 06:59 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
It is a TRUE cold air intake system. It may have a "few" restrictions in it. But the way I look at it, a 350 breathed thru it, its plenty good for my v6.
I have done the same as you. Removed them "wings" and plan to drop some k&n in it.
I never had the stock setup on my car, so I dunno if it was a gain, loss, or same.
Old Mar 5, 2003 | 01:14 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Biggest restriction I can think of is the MAF....which you aren't gonna be able to mess with, so..looks fine to me!
Old Mar 5, 2003 | 01:38 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
the only thing i did to the MAF was to take out the screen. It's been out now for 6 onths and I've never had a problem with it. I think my next thing to do to it would be to replace most of the rubber duct between the MAF and TB with a nice peice of aluminum to try to make the air flow smoother and straighter, what do you guys think?
Old Mar 5, 2003 | 02:09 PM
Nixon1's Avatar
Make sure you've got flexible joints between the throttle body and the aluminum, and the MAF and aluminum. The flex piece is made flexible for a reason...if it's too stiff, when the engine torques, it'll rip the sucker off at the MAF, etc.
Old Mar 5, 2003 | 02:48 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
convert to SD.............
Old Mar 5, 2003 | 03:56 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
was thinkin' of that at one point, but I don't have the time or money to go out and find a new ECM, Digital EGR system and all of the rest of the stuff that will make that work. Just lazy I guess. But I am glad to know that I have a good intake for being stock.
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
