Whats the easiest way....
Old Mar 12, 2003 | 09:49 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I've got a 91 RS V6 and i noticed as I was changing oil, there was some anti-freeze coming out of a cover back behind the oil pan and in front of the transmission fluid pan (prob a dust cover).I think it may be the intake gasket leaking.How do I see if it is the intake gasket and if it is, what is the easiest way to put one back on???
Ken
Old Mar 12, 2003 | 09:56 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
get the engine up to operating temp and let the stuff dry. It will leave a white chalky trail from where it is leaking. If it is an intake gasket, You will need to remove the plenum, injectors, fuel lines and then remove the intake manifold.
It is a labor intensive project but fairly cheap when it comes to parts.
Old Mar 12, 2003 | 10:06 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I would think if its coming from that area, it would be a freeze plug on the back of the engine.
Elephantismo
Feb 13, 2019 12:51 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Zane Story
Oct 8, 2015 12:40 PM
88CamZ
Oct 8, 2015 10:29 AM
