up shift light
Old Mar 15, 2003 | 06:34 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
up shift light
ok i was sittin in my car today 89 camaro RS with a 2.8 and th 400 trans..or maybe its a 700 r4?? but anyway thats beside the point, the sun was hittin the dash and i saw theres a dummy light for upshift..now this does sound a bit stupid but can i make the up shift light work with my auto trans? if so how?
Old Mar 15, 2003 | 08:33 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
i find it strange they put a dummy shift light in, u sure its not just burned out? are there wires going to it? i doubt u'd ever see it light on an auto tho.
Old Mar 15, 2003 | 08:36 PM
Transmission: autos
i got it up to 5500 rpms to see if it did light, and no it didnt, im not even sure if there a bulb in it, i just wanted to know what i need to do to make it light up, what rpm do they normally light at?
Old Mar 15, 2003 | 09:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
RBob told us a while ago (do a <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a> !) that the bulb circuit is also controlled by the 700r4's TCC signal. If a bulb is placed in there, it will light every time the TCC engages. The light is shown in the owner's manual. Don't you guys buy owners manuals for your cars? http://www.helminc.com First purchase I ever made was the shop manual and owner's manual. I bought the Haynes manual a few months later.
And yes, it's a TH-700r4. I doubt our v6's could spin a TH400 very well!
Old Mar 16, 2003 | 02:34 PM
Transmission: autos
ok well i went out there this morning and checked, no bulb so i tried to put one in...**** there went the bulb for my side marker, no connectors back there..just a hole to never never land..also my low water and and overheat dummy lights dont have connectors..arent those supposed to work???
Old Mar 16, 2003 | 03:33 PM
devianb's Avatar
My shift light comes on when I press the accelerator in 2nd, 3rd, and 4th gears and then goes out when I let of the throttle. It is really annoying because it never came on before and ever since my shifter broke, it suddenly came on. The light is useless. I want to get rid of the light but I can't figure out which bulb to take out.
Old Mar 16, 2003 | 06:33 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
When I had my 87 firebird with the auto someone had wired in the shift light for it. I would be driving along, and it would pop up at like 2500, then shift. Don't know anyone would do it that way, or set it up. But hey if its there, you might as well have it work, even if it is useless for the auto...
Old Mar 23, 2003 | 10:46 PM
badboy's Avatar
light
the light is for 5 speed trannies to tell you when to shift for fuel economy
Old Mar 23, 2003 | 10:58 PM
devianb's Avatar
Re: light
It may be for a 5speed, but I have it in my auto and it is driving me crazy. I don't want to see any lights come on while I am driving.
Could someone pleeeaaaaaaaase tell me where this socket is.
There are like 12 bulbs back there, and I have no idea which one it is.
Old Mar 23, 2003 | 11:07 PM
badboy's Avatar
light
for starters i dont know why that light is even coming on in an auto but if it bothers you so much take the cluster out and pop the bulb out of the shifter light socker
Old Mar 23, 2003 | 11:29 PM
devianb's Avatar
Re: light
I would do that except for one minor problem, I don't know which socket it is.
Old Mar 26, 2003 | 01:39 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
i removed my guage cluste panel and looked and i don't have bulbs for my upshift light, water level, or engine temp. I think those are the names, but anyways i've got a 5 speed. u dont need engine temp b/c you've already got a guage for that and most people dont want an upshift light b/c they like to shift when they want. and water level isn't really necessary b/c if u had no water obviosly ur engine temp would increase.
Old Jul 17, 2014 | 09:25 PM
94ElBanditoDeCa's Avatar
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
Re: up shift light
I have a 88 Firebird with a 5-speed BW tranny and I barely learned about the shift light. I want it to work but it doesn't.
If its not to late the for those who want to take the bulb out its not hard to find. Just do a lil trial and error by taking some of the bulbs off and pop the console on with the key on to see if it lights up. No harm in trying thats what I did it only takes less than 20 minutes.
Old Jul 22, 2014 | 12:58 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: up shift light
I think they made those all the same to be universal between manual and auto cars.
To take out the light you have to take off all the torx screws for the bezel and then there are two 10mm nuts at each bottom corner of the gauge cluster and you also have to take of the 6 or 5.5 mm screws around the cluster and pull the cluster out.
Then you unscrew the socket from the printed circuit on the back. its kind of easy.
If you have something that can reach into the little area where the light is without breaking the light. The bulb just pops out of the socket. Otherwise you have to take the cluster out.
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
