Distributor base leak
Old Mar 20, 2003 | 03:46 PM
grimesjm1's Avatar
Is the black rubber o-ring on the dist. shaft all that keeps the oil from leaking out the distributor? Mine is leaking like crazy and I have the o -ring in place, could it have failed from the distributor being removed a few times recently? thanks
Old Mar 20, 2003 | 04:58 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Guys, correct me if I'm wrong, but yeah as far as I know that o-ring is all that keeps the oil from pouring out. I don't think just moving it (to set timing) would be too much of a problem, unless when you put it on, something didn't seat correctly. I didn't have any problem after moving mine a little. Did it start leaking after you moved it for timing?
Old Mar 20, 2003 | 05:14 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Re: Distributor base leak
Yes that is all that holds the oil back. I got tired of it not sealing good and added a distributor base gasket for a V8 as well as a new o-ring.
Old Mar 20, 2003 | 07:50 PM
grimesjm1's Avatar
thats a good idea about the v8 gasket, i think i will do that. and i didnt move it to change timing, i removed it to replace the pickup coil and ignition module, and it started leaking then. the car had also sat for about 6 months before i removed the dist., too
Old Mar 20, 2003 | 08:53 PM
tell me about this v8 gasket...why is it better, cuz that might be a good thing to do b4 i put my engine in my car
Old Mar 20, 2003 | 09:54 PM
KED85's Avatar
This is such a simple mission. I was the one that told many about doing this.
Cause I've done it twice & total success both times.
BUT NOW, I'll suggest this, also.
Add to your new "O" ring on the distb. shaft, the SMALL BLOCK CHEVY DISTRIBUTOR GASKET and use a film of black RTV.
While ya have the distributor out, rebuild it. That's a simple mission also.
Benefits a plenty.
Trouble is, find just a simple Small Block Chevy distributor gasket!
I now suggest ya use both items together.
Works so well.
Gasket costs about $1 & the "O" ring about $.50.
CLEAN CLEAN CLEAN ALL SURFACES very well!
IF ya can, let the surfaces dry overnight for true leak free operations.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
