Windshield Sprayers Wont Work!!
Old Mar 23, 2003 | 07:56 PM
firebird13's Avatar
K um.. my wipers work fine..motor works but it just wont spray..wtf do i do..?? does this means motors burn out..because it makes a noise..when i do it?
Old Mar 23, 2003 | 08:03 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The washer pump may be shot. Replacements are around $10/15. Located at the base of the wiper motor were the fulid hose connects.
Old Mar 23, 2003 | 08:32 PM
firebird13's Avatar
So its really not that hard is it that circle celender under motor??
Old Mar 23, 2003 | 08:36 PM
DJP87Z28's Avatar
Thats it.......
Old Mar 23, 2003 | 08:39 PM
firebird13's Avatar
So thats like a 10 mins job??
Old Mar 23, 2003 | 09:32 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
There is a little clip that you pull out then just pull the pump straight down. The clip has a little tab behind it that you have to push in to get it to slide out.
Old Mar 24, 2003 | 12:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The motor is a metal shaft that spins a plastic impeller. If the impeller area runs dry, the metal shaft burns a hole in the center of that impeller. So the motor runs, but the impeller stands still, doesn't push any water, and you're stuck dropping the coin on a new motor.
Happened to me 3 times already... same problem each time. When I hit the junkyards this summer I'm looking for a washer bottle with a pump in it (used on the f-bodies with rear window wipers), and rigging my pump up to use the in-bottle pump instead of the on-wiper-motor pump.
Old Mar 24, 2003 | 07:23 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
88 and up F-bodies also have the motor in the washer bottle
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
