V6 Lowering Springs
Subscribe
Mar 24, 2003 | 04:27 PM
I'm looking for two inch lowering springs for my V6 Camaro... They seem fairly difficult to find, and some companies say they don't even make them... Anyone have any suggestions? Thx!
Reply 0
Mar 24, 2003 | 04:39 PM
Try doing a search. This topic has been gone over in depth before numerous times.
Reply 0
Mar 24, 2003 | 05:02 PM
V6 lowering springs
Thanks but I'm looking for someone helpful... I barely know how to use this site, thanks for being my first post.
Reply 0
Mar 24, 2003 | 09:38 PM
Welcome to the board.
First I would like to say that your going to have a tough time finding 2 inch lowering springs for your V-6. Myself, I feel your better off getting V-8 lowering springs for the rear end, and drop spindles for the front. As you will see most lowering springs are for V-8 cars.
The normal force acting on the V-8 springs is greater then that of the V-6 springs. So if you put in V-8 lower springs you might actually get a higher car in the front then you originally had.
So that is my reasoning for V-8 springs in the rear, and drop spindles in the front.
Now here are a few old threads.
https://www.thirdgen.org/techbb2/sho...wering+springs
https://www.thirdgen.org/techbb2/sho...hreadid=160625
And another thing, you really don't want to have to buy new springs to cut them. Another advantage drop spindles.
Reply 0
Mar 26, 2003 | 09:30 AM
Cutting a high quality , new aftermarket spring isn't a big deal, as long as you don't go crazy with how much you cut, or use a torch to do it with.
We used Eibach Pro Kit springs for a V8, cut 1/2 coil in the front. Easy. If you don't cut them, the car will sit higher than it would with the engine out! Eibach recommended we cut them for this application BTW (87 2.8 V6 Firebird).
They have been in for over a year, and haven't sagged, lost tension, or anything else people tell you springs will do when they cut them. Cutting used original springs is a different story, though.
Next one we do, we'll probably use Sportlines though for a little more drop...not sure if they'll require cutting or not.
Reply 0
Mar 26, 2003 | 10:09 AM
Here is a larger pic of my car... We used a cut of wheel to cut mine...
Reply 0
Mar 26, 2003 | 06:33 PM
I got a set of suspension techniques it was a 1 inch drop looks good gets rid of that gap in the back wheelwell. You do have a more bouncy ride at first it sux then you get used to it.
Reply 0
Subscribe
