TPI Intake
Old Mar 29, 2003 | 03:53 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
TPI Intake
So if I wanted to switch my 3.1 can air intake to a TPI, How hard would it be?
Old Mar 29, 2003 | 06:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes you can. Its very easy. But the top and bottom, some air filters, then a short section of 3" pipe. I used exhaust pipe. Later I will cut up a euro intake pipe, and install it.
You place the pipe where the maf should attach.
see my website for pictures.
Old Mar 30, 2003 | 04:18 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
3.1 RS i has bouth the Cold air intake and then i puechased the dual snorkel intake and put 2 K&N's in it and completly cut the bottoms off so the filters were basicly exposed and personaly i liked the CAI intake more and also when u use the dual snorkel intake it gets heated from the radiator and if you put your hand on it after driving it is very hot which means your air isnt as dence since its getting heated by the radiator if thre is a way so it dosent get heated then it would work great.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
