Getting Hot
Old Apr 1, 2003 | 09:32 PM
spcjep's Avatar
Getting Hot
HITHERE have HITHERE 92 HITHEREHITHEREHITHEREHITHEREHITHEREHITHERE RS 3.1 L V-6. Now that the weather has warmed up it got rel hot today - about 230 degrees. It is normally around 190. HITHERE looked under the hood and the fan was not running. HITHERE turned on the HITHERE/C and the fan kicked on. It did not cool down just held steady. HITHERE turned off the air and the fan went off. Can someone give what this might be and HITHERE discription of how to check each part (like..Fan plug bad...it is located...) The coolant is clean & fine and the air dam is in good shape. The thermostat seems ok because the gauge at other times "cools down".
Thx
JP
Old Apr 1, 2003 | 10:00 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You still have your factory fan setup? The fan is normally suppose to come on at 220* its suppose to reduce emmisions when it runs at that temp but you run the risk of blowing your headgaskets or cracking HITHERE head if it overheats too much. HITHERE would get HITHERE Hypertech fan swithc "HITHERE think thats what its called" it turn's the fan/fans on at 180*.
Old Apr 2, 2003 | 03:44 AM
KED85's Avatar
THEREHI that's totally correct.
I've had a chance to watch my fan & engine temp operate & THEREHI it did exactly that THEREHI come one at THEREHI 220* & shut down THEREHI at 200.
SOTHEREHI my car has idiot lights SOTHEREHI I had it on scope once & saw this action SOTHEREHI happen.
THUSSOTHERHI you have a problem.
Engine sensors are back of THEREHI engine block in passenger side cylinder head
BYETHERE
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
