V-6 Shocks & Struts
Old Apr 8, 2003 | 08:09 AM
  #51
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by KED85
Do I need use a spring compressor?
OR just hold lower a-arm with the HD Floor jack?
ONLY CHOICE IS AIR IMPACT GUN.
Set on stun.
I'll spray those bolts now!
I don't recall using a spring compressor.
Spring, ball joint, spindle all stay in place. Will need a jack or some blocks under the A-arm though.
RBob.
Old Apr 8, 2003 | 08:55 AM
  #52
KED85's Avatar
MANY THANKS
That's pretty much what I recall.
Undo the bottom two bolts, undo the top nut, remove old strut, install strut, release the cord holding compressed new strut, attach bottom two bolts, done.
Why do they call this "strut" a "strut" when it's a variation? if correct?
Real struts go thru coil springs, true?
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
