V6 auto same as V8?
Old Apr 9, 2003 | 11:28 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
V6 auto same as V8?
I have an ailing 700R4 tranny in my L98 car, and I am looking to pick up a junkyard special trans to have rebuilt. Finding one locally has been a bit of a pain and I wonder if the Auto/OD trans from a V6 is the same... anyone know FOR SURE (no guesses needed, thanks!)...
Thanks in advance!
Old Apr 10, 2003 | 12:19 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
No
the case is different in that the bellhousing bolt pattern is unalike and can not be adapted to fit
also, while MOST, of the same internals are used, the V6 700R4's used less clutches in their packs, thus making them weaker and less suitable for V8 power
to top it off, the input shafts are also different
the V6 700R4 is sometimes referred to as the "baby" 700R4
Old Apr 10, 2003 | 11:30 AM
DURTYBIRD's Avatar
Originally posted by 1991tealRSt-topGuy
No
Waaa!
Old Apr 10, 2003 | 12:39 PM
Camaro_nut's Avatar
Yep!
It's 100% true, as stated from 1991tealRSt-topGuy,
You can not use a V6 trans. for a V8 motor.
You'll have to either go to the junkyard to find a V8
700R4 trans., and have it rebulit to hold whatever
amount of horsepower, or buy one new, factory or
"punched out" ( high performance).
Try Jegs.com for one. I think they run about $1600
without a torque converter. I think TCI makes
a decent one.
Also, try using your search engine on your internet
service to check ones nationally.
You can also try Ebay.
Old Apr 10, 2003 | 05:26 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
another source to find em would be trans am creations, or even thirdgen resource and hawks thirdgen parts. Both stock em i believe, and that would work. Or call some local tranny shops, i'm sure someone knows where you could find one, or they could find one and put in.
The camaro/firebird v6 tranny is different, however. If you find say an S-10 or jimmy that's using a 4.3L v6 and has a 700R4 the transmission is the same as the v8 one. Be sure that the car is a 4.3L though, as a 2.8L won't work. If you get a chance to see both transmissions out of the car, you'll notice the drastic difference in the bellhousings and compatibility issues.
Old Apr 10, 2003 | 05:58 PM
DURTYBIRD's Avatar
hawk and 3rd gen are probably gonna want good money for theirs... I just need a 'core' really.
On the s10 and Jimmy trucks, what year did they go VSS? I have a '91 and it has the VSS for the speedo.
Old Apr 10, 2003 | 06:22 PM
Camaro_nut's Avatar
I don't have an answer for you here, but you can
try calling your local Chevy dealer and ask a tech
or parts guy, they should know!
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
