check engine light problems....
Old Apr 14, 2003 | 01:01 AM
bes217's Avatar
I have a really weird thing going on with my check engine light. Whenever I first start up the car it goes on. Then, if I shut down the engine then turn it back on again the check engine light does not come on and stays off. Does anyone know why it could be doing this. I have reset my computer and everything by disconnecting the battery. But, the problem keeps coming back. I have pulled the codes before and it says that I am getting a code 34:MAF sensor, and code 54:fuel pump circuit. Any help would be greatly appreciated.
Old Apr 14, 2003 | 01:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Click on <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a>, and search for "code 34 chart" by "TomP" on the "V6 Forum". Then search for "code 54 chart" by "TomP" on the "V6 Forum". I typed both charts straight out of the GM Service Manual for you guys. They're easy to trace, and I pretty much spelled everything out in 'em. Good luck!
Old Apr 14, 2003 | 01:29 PM
bes217's Avatar
But Tom do you have any idea why it would come on the first time I start it, then when I turn it off and start it again, the light does not come on?
Old Apr 14, 2003 | 04:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Probably because you're confusing it? Beats me. You'll have to run the charts to find the problem.
Old Apr 14, 2003 | 11:40 PM
bes217's Avatar
OK, thanks for the help. I found those charts and will probably run through them tomorrow.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
