help headlights wont work!
Old Apr 17, 2003 | 10:06 PM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
Help guys,
I got in my camaro tonight and pulled the **** out for the headlights and they didnt come on! I have no clue whats wrong, any help would be appreciated, thanks-jmb
Old Apr 17, 2003 | 11:49 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Fuse?
Old Apr 18, 2003 | 06:44 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
First, I believe the headlights are on a circuit breaker.
Is anything else not working? Interior lights? Lighter? Horn? Radio? If all those things are out I'd suspect a fusible link is burnt out.
Old Apr 18, 2003 | 10:55 AM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
lights
the interior lights are dead: dome, gauges. The blinkers and brake lights work fine, dont know about the horn
Old Apr 18, 2003 | 11:55 AM
Nixon1's Avatar
I know the lighter and dome are linked together, but I don't think the gauge lights are.... Doesn't sound like it's at the fuse box.
Old Apr 18, 2003 | 12:00 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I'd put my money on a burnt out fusible link.
I'll describe the scenario going by my 86 IROC. On the "B" terminal of your starter, you have the positive battery cable, and three smaller wires. One wire has its own ring connector, the other 2 share one. The one by itself is the voltage sensing wire to the alternator. The two that share a ring, one of those supplies power for your lights and everything on the Accessory fuse. Get the picture? It's basically everything that should work with the ignition off. Except the hatch motor, that's on the other link.
Again, I described how my 86 IROC is wired. I forget if the v6 are different.
Old Apr 18, 2003 | 12:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Could ask on Tech or Electrical forums, the wiring isn't specific to a v6.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
