Rim and Tire question
Old Apr 19, 2003 | 12:20 AM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi Guys, I am the Chinese in Taiwan.
Pls help for the question below.
I went to store asking for rim & tire change but they found the 3thgen got special PCD and Offset with others car, so they have to check, there is only few 3thgen firebird still drived in Taiwan and they know the car very poor. can you guys tell me about the rim PCD and offset and any information I would know in the rim and Tire changing.
I got 15" stock rim now (205/65/15 in the front, 225/60/15 in the rear), if it could works, I like to change it to 17", pls tell me how wide is the tire can be done??
(both front and rear, 235, 255 or 275??)
if it doesn't work, how wide is the tire can be done on my stock 15" (front and rear?)
Thank you for your help.
Joe
Old Apr 19, 2003 | 12:44 AM
92CAMRORS's Avatar
I found the rim offset here on thirdgen.org but for 16 inch rims, although I would assume they are the same for 17 inch rims as well.
0 mm on the front and 16 mm (negative - outward) on the rear.
I'm not sure about your other questions, but I am sure someone else here can help you out.
BTW, you live in Taiwan? That is awesome!
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
