No response on tranny board...
Old Apr 19, 2003 | 11:03 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I was trying to drop the pan today, when I found out that the crossmember was in the way. Is it just the V6 that has this problem? How would I get the pan out if those bolts are behind the crossmember? (If I remove the crossmember, the tranny falls right?)
Old Apr 19, 2003 | 12:28 PM
Akshay's Avatar
It won't fall, but it is heavy and will lean down. The leaning will mess up the tranny to engine seal...it may start to leak.
You need to support the tranny before removing the crossmember.
Akshay
Old Apr 19, 2003 | 10:03 PM
KED85's Avatar
You out to change the fluid & filter or cure an ill tranny....?
The pan drops easy enough for this mission.
BUT, it'll still spill, so expect that.
Fluid change should be once year.
I plan on trying that theory to see how long I can make a tranny rebuild (& a good one) last.
Old Apr 20, 2003 | 01:18 AM
89V6FBIRD's Avatar
Ahhh got lazy. Had Pep Boys run their complete tranny flush through it. Filter and like gallons of ATF used to clean the sucker out.
Needed to do this because the last time the fluid was changed was like 4 years ago. Fluid was still red and didn't smell burnt, so I'm fine.
Old Apr 20, 2003 | 06:40 AM
KED85's Avatar
I hope you did a good thing.
Time will tell.
New trannys & fluid changes have a way of getting to be funny. And not when they decide to change mode of operations on ya!
Old Apr 21, 2003 | 01:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: No response on tranny board...
It's close, but the crossmember isn't in the way. I can fit my 13mm 3/8" socket behind the crossmember with no problems. Undo those bolts first so you can remove 'em by hand when clearance gets tight. The bolts are only in (er, make that, SHOULD only be in!) at 15-18 ft/lbs, so they're not cranked in there. (Er, well, they shouldn't be cranked in there... it's a steel bolt going into aluminum threads, too much torque and they can strip out!)
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
