Rough & Low Idle
Old Apr 25, 2003 | 08:20 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Rough & Low Idle
My car has a really rough and low idle, and sometimes when I am stopped at a stoplight it will just die. Is my problem the wires and plugs or could it have something to do with my new intake?? please help thanks....
Old Apr 25, 2003 | 08:44 PM
Akshay's Avatar
EGR, PCV, ign. coil, engine can't get clean air, could be cap and rotors.
Akshay
Old Apr 26, 2003 | 12:27 AM
Rustyd2k2's Avatar
I would think that your having problems with your EGR valve. Because i had some problems with my egr valve and it idled like **** and cut off at redlights. But it was idling high most of the time. The egr valve is made for emissions and it has alot to do with your idling. Reply back with details.
Old Apr 26, 2003 | 02:59 PM
Quick6's Avatar
Thats pretty much what happens, how do I fix it??
Old Apr 26, 2003 | 03:17 PM
Rustyd2k2's Avatar
you have to either find out whats wrong with the EGR valve or buy a new one and install it. what happened with mine is the screws broke off and the whole egr vavle was leaking air. you have to get up under there and find the problem. send me a pic of your engine and ill circle the egr valve.
Old Apr 26, 2003 | 08:27 PM
bes217's Avatar
Have you checked the IAC valve. Those are the symptoms of one that is out of whack. Take is off and clean it and set it to the factory settings. If you need info on this be sure to use the "search" button first. Just type in "clean IAC" and you should get what you are looking for.
Old Apr 27, 2003 | 05:07 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
First of all it's NOT your EGR, remember the 1991 had a electronic EGR vs the old vacum type and the computer will set a code if it doesn't like it.
IAC trouble, I bet when you turn the A/C on and stop it dies.
Replace your IAC and see what happens. I remember mine falling apart in my hand it was so died.
If you think your intake is a problem, put the old one back on and see.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 15, 2015 01:17 PM
