Oil pressure?
Old Apr 30, 2003 | 09:07 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
Oil pressure?
Just fixed my sending unit and gauge and sometimes my oil pressure is 70-75. today i started it for the first in 48 hours and the pressure was pegged at 80psi. after a while it drops to around 70 or 75. when driving i see it drop to around 40psi every once in awhile. is this normal for a 3.1L? does high oil pressure indicated that theres something wrong, clog somewhere or something? i noticed that the v8 engines had 0-60 gauges, do the v6's just need higher pressure?
Old May 1, 2003 | 12:58 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I don't know about the need for more pressure, but I do know my 3.1 always had high pressure (70 psi min) sometimes at idle it would drop to 40.
Old May 1, 2003 | 02:37 PM
TekViper's Avatar
Engine: 3.1L v6
any other people w/ 3.1L and working gauges? what are your pressures.
Old May 2, 2003 | 02:07 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
High oil pressure is always good. Mine rarely drops below 70 and like his sometimes hits 40 at idle. Other than that it is always at 80 when accelerating, so I think its completely normal, I thought I had a problem as well. From my understanding high oil pressure is a good thing.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
