87 firebird frontend on an 89
Old May 1, 2003 | 10:13 PM
88MARO's Avatar
Can anyone tell me if the frontend of an 87 firebird will fit on an 89. I think that it will, but I just want to make sure. Thanks
Chris
Old May 2, 2003 | 10:43 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
What do you mean by frontend? The suspension? Yes. Body? Yes.
Old May 2, 2003 | 10:54 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Your probably talking nose cone. If so, then yes it will fit.
Old May 2, 2003 | 01:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have an '84 front clip on my '86... they -all- fit! Note that there are 4 bolts that hold each fender to the front bumper cover. Two are real bolts, 10mm's, and can be seen from the bottom of the bumper. Two are "fake" nuts, just metal stampings. I believe I used a deep 7/16" socket on them. Your -best- access will be to remove the headlights.
KEEP IN MIND PANEL ALIGNMENT!! If you remove the headlights, you need to keep the original alignment. Use a can of spray paint over the headlight bolts/frame so you can put the headlight back. The holes are slotted, which allows the headlight to be aligned to the hood, fender, and bumper. It's important to align with the hood. If you're not aligned correctly, when you turn on the headlights and the door flips up, the door can scrape the hood cutouts. I unplug the motor, and work the **** by hand to check alignment of the hood to the headlight doors. Pop hood, turn **** a bit, close hood slowly- if no interference with headlights, click the hood so it latches, check alignment. Pop hood, turn **** a bit more, close hood slowly, etc etc over and over again until the headlight's all the way up. It takes a LONG time but it's worth it to protect your paint.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
