Finding the TPS on a V6
Old May 2, 2003 | 05:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I've been looking all over my throttle looking for the TPS and cannot find it. I have a Haynes booklet here that shows where the V8 TPS is mounted but I am unsure of where the V6 is and how to adjust it. Is it the round plug under the IAC? If so how do I adjust it? Thanks.
Old May 2, 2003 | 06:50 PM
omarbreadbeek's Avatar
it should plug into your throttle body...
Old May 2, 2003 | 06:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Maybe you shouldn't be adjusting it. It would depend on the year and engine size of your car... which you didn't give us.
Old May 2, 2003 | 07:16 PM
pasky's Avatar
I've already found it. Its the round 3 plug wire right below the IAC. The reason I am about to adjust it is I have already replaced my IAC and tried messing with the min air idle screw but my throttle lever doesn't even touch the screw. Itd about 2 cmm from the screw and wont go any farther back. Im stuck at 1500 rpms and need to find out what the cause of it is. Anyone know why the throttle lever would not be able to go back?
Old May 2, 2003 | 07:17 PM
pasky's Avatar
Also, how do you adjust the voltage on it?
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
mdtoren
Aug 16, 2015 05:45 PM
