Timing chain install help ASAP
Old May 9, 2003 | 10:09 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Im trying to install my new timign chain when i go to put the gears and chain on the top one wont line up it wants to go to the right and there is too much tension on it to get itt o go in the key hole so i can blot it up ive tried sliding themon as 1 pice any ideas???? Karl if you come an help me ill give ya a free water pump in a few weeks for a 3.1 should fit the 2.8 as well.
Old May 9, 2003 | 11:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I bolted the crank one on. then slid chain over, and had to use the bolts to put the cam one on. However, I test fitted prior too, and made sure my two marks were alighned properly. I did have to bump the crank one way to make them work. Cam may need slightly moved in your case.
Old May 10, 2003 | 12:59 AM
FAST RS's Avatar
i got them on my girlfriend came up with an idea i knew she was good for something. But now i lost 1 waterpump bolt so im going to have to get a new bolt tommorw i have no clue where the bolt went to.
Old May 10, 2003 | 06:01 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As long as it isn't laying around behind your timing cover
Old May 10, 2003 | 06:23 PM
FAST RS's Avatar
The timing chain defeated me i got a harmoinc balancer installer and the bolt that threads into the crank broke off so i said **** it and had my car towed to my frineds shop at 3 am.
Old May 11, 2003 | 02:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh hell; how did the bolt break in the crank?? Is there something your friend can get a grip on? Or did it snap flush with the snout of the crank, like mine did? That sucks... keep us posted!!
Old May 11, 2003 | 03:57 AM
FAST RS's Avatar
There is enough to get a grip on it he just has to pull the balancer. I basicly said **** it at 2 am and had it towed to his shop a few miles away. Since its there i just gave him a list of stuff to do.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
dutch930
Sep 11, 2015 06:58 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
