is this my starter?
Old May 15, 2003 | 10:24 AM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
is this my starter?
lately my car hasnt been firing right up and may need a second try. well yesterday i drove it to school. it started on the second try. when i came out after it had been sitting for about 6 hours i use my keyless entry thus indicating that my battery was not the reason for this. all of my electronics are working. when i turn the key to the acc position i can heard my fuel pump priming...and then i go to turn the key and NOTHING.
not a **** thing happened other than my temp gauge goes up when the key is turned and goes down when i stop
what could this be?
Old May 15, 2003 | 03:06 PM
SAEspinz80's Avatar
It can one of two things. I could be your starter or your VATS. When was the last time you did the starter? It could be the problem.
If its the VATS, the following will happen:
VATS is that black resister that sits in your key. It needs to touch two wires inside the ignition cylinder in order for the car to start.
Try this. Insert your key and turn it to the on position. Now look and see if the "SECURTIY" light is on or off, it's is located off to the right side. I "believe" if it IS working, then the securtiy WILL come on, and the car will start.
If it is NOT working, the security light will NOT come on. If the security light is NOT on, then your car isn't seeing the resistor in the key and thinks you are trying to steal the car and won't start.
HOWEVER, I could have this BACKWARDS. I sold my Firebird two months ago. Someone who still has the car has to confirm this.
FIX: If your lucky, it can be as easy as replacing your key for 25.00. However, when it happened to me....and it did at around 114,000 miles, a mechanic had to re-solder the two wires inside the ignition coil. One of them had come loose.
Old May 15, 2003 | 05:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
this almost sounds like what happened with my GP. All electrical would work, but nothing when the key went into start. Turned out the starter was fried (warranties are great ) .
WIll it jump start? mine did it once, then finally died at the house.
Old May 16, 2003 | 07:30 AM
SAEspinz80's Avatar
Here's the link to my ORIGINAL post when I had the problem. It should answer most of you questions.
https://www.thirdgen.org/techbb2/sho...ighlight=start
Old May 16, 2003 | 07:47 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Right.. and if it ISN'T your VATS, then it could be:
Starter
Starter Solenoid
Park/Neutral Saftey Switch (Auto)
Clutch Saftey Switch (Manual)
Cut/Shorted Lead to Starter Solenoid
Cut/Shorted Lead(s) to Saftey Switch
Corroded battery terminal
Old May 16, 2003 | 10:24 AM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i never actually thought that my key would be the reason...as soon as i get home im gonna try to start it up with my spare set. even though i know that its going to end up costing some cash just because of my bad luck.
i have an exhaust leak that i was actually going to get fixed the day that my car wouldnt start...
if its just my key then ill be able to drop my car off today after school
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
