what is this???
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
what is this???
Ok on my 85 camaro if you stand in the front of it and look down on the lower passengers side of the engine theres a pulley thats attached to something. Since im new at this Camaro V6 thing i have no clue what it is. I seem to have seen a post or 2 bout smog pumps, is that it?? What would happen if i cut the belt off to it
Originally posted by Cold Dark Shado
whats the point of it??
No, it was easy, but some say its hard to get those 3 pipes off the exhaust manifold just 3 bolts to take off the pulley and two for the pump. Two years ago when I first joined this board as Executivecamaro I had those three pipes broken so it was cooking my wire harness it was the first time I ever worked on a car seemed easy to me
Engine: 305 carbed
Axle/Gears: unknown
yea i cut the belt out off the AC compressor and im goin to remove the rest of it soon so i might as well remove the smog pump while im at it
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The point of the smog pump is so that when you decelarate, you get oxygen into the catalytic convertor so that it functions properly. As far as I know, it only came on manual transmissions because of the higher rpms that you make when you down shift to slow down. You need it if you have to pass smog, if you don't and don't care about putting out extra emissions, then by all means take it off, it'll reduce drag on the motor and give barly noticable extra power.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The pump is supposed to be there, and if the pump is actaully removed when they do the visual inspection, they are supposed to fail you for not having the proper smog equipment installed. You're car will run fine without it. You shouldn't see a code or anything for it, but your car will put out more NOX when you down shift. This is because the the engine spins faster, but the throttle plate is closed, so since the RPMs are higher, the computer will keep firing the injectors for the faster RPM. The smog pmp just adds extra air to the exhaust so that the catalytic converter can operate efficiently and without overheating.
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i have one on my 91 RS automatic. no...you will not get problems from removing it...mine is still there but not hooked up...
