underdrive pulleys, blasterII coils and aluminum dshafts!
Old May 27, 2003 | 07:52 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
ok so i got this 3 things on the way
ive dealt with driveshafts so i know how to work/install that
had the distrubutor pulled apart as well and know how that works....
i just wondering about installing the pulleys, ami going to need anything to pull the old ones/install the new ones, or anybody have any info to help me out for when they get there??
Old May 27, 2003 | 08:05 PM
MadZ28's Avatar
Car: 91 Z28
dont need much
From my experiance with these, you only need the wrench's to get them off. Remember where they go.
Old May 27, 2003 | 11:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Leave your belt on while you loosen the bolts holding the pulleys to the engine. The belt will help keep the pulleys from spinning. If you forget, as I have, you can usually tighten a c-clamp down "around" the pulley, so the jaws clamp down on the flat middle part, to keep the pulley from spinning.
Are you doing each mod by itself to get a feel for how it improves the car? Or are you doing them all at once?
Old May 27, 2003 | 11:39 PM
Engine: 3.1
i was going to make a day throw all 3 on in the same day
next thing is a rear end
Old May 27, 2003 | 11:41 PM
Ovrclck350's Avatar
I always use 2 seperate ratchets/sockets to tighten/loosen pulley's.
Old May 28, 2003 | 06:46 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The center bolt on mine was 17mm, I think the others were 13mm??
I left the belt on, loosened, then took belt off, pulled crank off.
If you got the alt pully too, take the alt off, put on a vise, and use an impact and some chanel-locks to get that one off.
Hereing these good things on a driveshaft is making me want to get one.
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
timonator
Sep 17, 2015 06:57 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
