Don't think its VATS, any ideas?
Old Jun 8, 2003 | 02:21 PM
87SC/SS's Avatar
Car: 92,94 Camaro, 95 Bird, 12 Silverado
Engine: 5.7, 3.4, 5.3
Transmission: 700R4, T5, 6L80E
Axle/Gears: 3.70, 3.42
Hey guys,
I don't know how many of you read my last post about my '91 Camaro RS 3.1L not cranking. So for those that didn't... The car cranks fine without the computer hooked up, however once I hook up the computer it won't crank at all.
As for the VATS system, I checked the keys and the wires at the base of the steering column and it all tests fine. One thing I did notice is that the tach isn't at zero its all the way on the other side of the gauge. The temp gauge goes to zero and the volt gauge goes to 12v when the ignition is on. I don't get a SES light at all. And when I tested output from from the ECM the TPS is supposed to get 5v but the ECM is putting out 11v, and the VATS is supposed to be feeding the computer 5v but its sending 11v as well. The fuel pump does kick on, and only with the ECM hooked up. A friend of mine suggested a possibly bad ECM. Does this sound right?
I have a thought and it may be stupid but I'm curious none-the-less. If the ECM is bad will a 7749 ECM from a Syclone or Typhoon work properly without the turbo? I do eventually want to turbocharge this, and have some rough plans, at least this way I'll already have the computer.
I'm more interested in the top part than the turbo part at the moment, so anything would be much appreciated.
Brian
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
