Retarded cam 2 degrees
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I accidentally retartded the cam 2 degrees as a result of some advice before I knew that the timing could be changed like that. What will happen if its like this? Is there some way to fix this with the distributor or do I need to tear everything back apart.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Retarded cam 2 degrees
dont feel that bad i replaced the dual over head cams on my
honda cbr 600 and was 1 degree off. if i was 2 degrees off on what
i did then i would have bent all the valves... 1 more degree and
i would have been looking at 1,000 in repair........
