rpms take forever to come down
Old Jun 10, 2003 | 04:13 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
anytime i have the clutch in or have the car in neutral, the idle jumps up to 2000rpms. it takes anywhere from 5 to 20 seconds to come down to idle speed. it sits at around 2000 and then slowly drops. i replaced the IAC valve already. any thoughts on this?
Old Jun 10, 2003 | 06:47 PM
drdave88's Avatar
Engine: 6.0L
no thoughts?
Old Jun 10, 2003 | 06:55 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Originally posted by drdave88
no thoughts?
none from me, i have no clue what could be causing it.
Others on here might, just give them time to respond.
Old Jun 10, 2003 | 07:24 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
Check your vacuum hoses to see if any are lose or cracked.
Vacuum leaks tend to cause high idles.
Old Jun 10, 2003 | 07:28 PM
drdave88's Avatar
Engine: 6.0L
no vacuum leaks, ive checked it all, over and over.
Old Jun 10, 2003 | 07:42 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Check your idle speed stop on the throttle body. Let the car idle in neutral, warmed up, and back that stop out. That should help you!
Old Jun 10, 2003 | 07:43 PM
drdave88's Avatar
Engine: 6.0L
it eventually gets to the idle speed, but it takes forever to do it. thats what the problem is.
Old Jun 10, 2003 | 09:02 PM
RustBucket's Avatar
Check the throttle linkage, and the throttle body butterfly mechanism for any binding or stickiness near the idle position. Open the throttle body and look inside to see if it's gummy right where the butterfly closes the entrance to the plenum. Another thing to check is the linkage to the cruise control if so equipped. Set the brake and observe the throttle linkage while this is happening. There could be something funky going on with the CC actuator causing it to create return resisitance on the throttle arm. Watch the throttle linkage at the throttle body as well as the CC actuator down by the driver's side headlight bucket. That should cover the mechanical part of it. Next step electrical and I'll probably be scratching my head too.
Happy hunting
Old Jun 10, 2003 | 09:07 PM
V6RSRick's Avatar
i kinda had the same problem, i had a mechanic look at it and they replaced the tps, and put a throttle return spring on...
sometimes it surges a little but not nearly like it did before.
before everytime i went to shift gears my engine would kinda rev, i hated how it wanted to burn my clutch
well its all fixed now, good luck
Old Jun 10, 2003 | 10:18 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
with the engine running, pop the throttle open and hold it, then close the throttle by hand and see how long it takes to get down. If it goes down quickly like it should, then the return spring is probably weak. Mine was like this so I went down to pep boys and bought a carb return spring and installed it on my car, problem fixed.
Old Jun 10, 2003 | 10:47 PM
Doward's Avatar
Maybe I was unclear... see, the throttle stop physically stops the throttle blade. If the blade is stopped too early, then it's up to the IAC to go from open, to close until the rpms come down. That could be causing it. close the throttle blade, and force the IAC to take up more of the idle load.
Elephantismo
Feb 13, 2019 12:51 AM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
the_hamturdler
Sep 22, 2015 02:59 AM
codeysabatini
Sep 20, 2015 11:36 AM
