rear defrost
Old Jun 11, 2003 | 05:15 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
rear defrost
hey, my rear defrost wont work and the light comes on when i hit the brakes. can anyone help me out? are there any specific thing i should check?
Old Jun 12, 2003 | 05:17 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
the wires coming from the rear posts to the wires on the window fall of all the time on EVERY car. i assume you have allready checked those. and when you say the light comes on do you mean the defoster light comes on when you hit the break?
if that is the case did you do any re-wiring/fix anything wire related recently.also check your fuse box, specifically wires behind it. two of them may be bare and touching.
hope this helps/point you in a good direction.
Old Jun 12, 2003 | 09:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Good call, X! That's what does it; I assume the car is an '86? As X said, the lines on the window for the CHMSL (center high mounted stop light, aka third brake light) fall off the window. They rest on the hatchback's gas-charged lift's piston. The pistons are the ground for the defroster. So when you hit the brakes and the third brake light activates, the defroster circuit gets grounded via the wire that's "touching" the gas piston for the hatch.
I had to use a high-heat soldering gun to re-solder the side "strap" traces to the window.
Old Jun 13, 2003 | 03:59 AM
Xophertony's Avatar
Axle/Gears: n/a
wow, thats not what i meant. but cool. i meant wires behind the fuse box were touching and that the wires going to the rear defrost may have fallen off, i did not know about the brake light thing. cool, now i do though
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
