FS: MSD 5a, MSD Blaster II Coil, Underdrive Pulleys
Old Jun 12, 2003 | 06:49 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
well im swapping up to a v8 so i stripped my 6 of what it had
trying to get rid of these all in one big package
100$ plus shipping and its yours
i paid
80 MSD 5a
107 for both Underdrive pulleys and Ignition Coil
Old Jun 12, 2003 | 07:28 PM
unvc92camarors's Avatar
post in the classifieds
Old Jun 12, 2003 | 09:33 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
on a technical note...what does the msd 5a and blaster 2 coil do and how does it help the car?
Old Jun 13, 2003 | 09:18 AM
Engine: 3.1
sends more spark through your ignition system
ex. i would launch my car without it and could go when the second yellow started to lite up....installed the msd 5a box and red lited going then had to wait for the second yellow to be all the way lit...
i never got to run the car at the track with the blaster II coil but i ran my freinds 97 3.8 and instead of her passing me at the top end of first and leaving me...i stayed out in front till the top end of second till she passed then i sat on her rear bumper....dunno if i would have passed her again cuz we ran out of street
Old Jun 13, 2003 | 09:40 AM
too bad i just bought a cam rocker rollers and a double roller timing chain...maybe in a month or two....
Old Jun 13, 2003 | 10:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
MSD made a 5a? I thought they just made a 5. Sure you don't mean a 6A?
Old Jun 13, 2003 | 10:46 PM
I'm still confused about this...
When I look up the blaster 2 coil it brings up a cylindrical thing as the coil, isn't our coil like a short kinda round thing?
So how would you hook it up?
and
Where does the MSD 5, since thats what I'm assuming you have cuz I can't find a MSD 5a anywhere, go and how does that hook up?
Maybe pictures could help?
Old Jun 14, 2003 | 08:22 AM
Engine: 3.1
yes its 5 my bad i dunno why i put a maybe i was thinking 6a when i typed it
damien i think your thiking its a new distributor, thats what i thought at first....follow the center spark plug wire over to the igniition coil.....mines mounted on the if your looking at the enigne your left side of the block
i dunno how the msd 5 installs i had somebody install it for me and he just tinkered with it till the car actually started, the rpms fly when you rev it after it was installed
ill get picks up when i get back from work
Old Jun 15, 2003 | 03:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
An MSD box wires into the coil connector for our cars. Think of an MSD box & MSD coil as one big factory coil.
You can also wire a blaster 2 coil (two wire coil) into our 4-wire coil connector. If you do a search on the v6 forum for "Blaster" by "TomP" in the "V6 Forum", you'll find my messages where I tell exactly how to wire one up.
Old Jun 15, 2003 | 11:42 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Are the Blaster Coil and the MSD 6A box something you would do together or one or the other or which one first? I'm curious....
Old Jun 16, 2003 | 01:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can do them both at one shot; or, do the coil first, and when you run out of bolt-on mods, then do the MSD box.
Old Jun 16, 2003 | 02:42 AM
Engine: 3.1
yeah i did it the other way round, but OMG the coil helped out so much!
still workin on the pics.....
i need a digital camera
Old Jun 16, 2003 | 09:59 AM
Engine: 346ci LS1
Transmission: MN6
https://www.thirdgen.org/techbb2/sho...laster+factory
There's what I found!
Keith, it's easy. It requires some splicing, but here's the quick overview. The four connectors on the GM coil are really a "bridge" to each other. The GM coil is basically two parts- a two-terminal spark coil, and a "2-to-4 connector". For instance; wire "A" on the gray connector gets connected to wire "B" from the black connector- inside the coil. Inside the coil, "gray-B" ties to "black-B".
1. Cut off the factory coil connectors (leave an inch or two in case you ever want to hook them back up) from the car's wiring.
2. Mount the new coil so it's within reach of your distributor cap. I think the MSD Blaster 3 needs to be mounted upright, right?
3. Cut yourself two lengths of wire, about 18 or 20 gauge, that will reach from the car's wiring to the location you want your new coil to be in. I'm going to call these your "MSD wires"...
4. Strip 1/2" insulation off the four wires from the car's harness, and off the ends of the MSD wires.
5. Attach the PINK/BLACK wire of the GRAY connector to the PINK/BLACK of the BLACK connector. Attach one of the MSD wires to this hookup... make them look like a "Y". Use correct methods (crimping or soldering, with heat-shrink or electrical tape).
6. Attach the BLACK/WHITE of the GRAY connector to the BLACK of the black connector. Attach the other MSD wire to this hookup. ** Note: This is where you would connect an aftermarket tachometer!
7. Take the MSD wire you connected to the PINK/BLACK wires. This goes to the POSITIVE terminal on the MSD coil.
8. The MSD wire you connected to the BLACK/WHITE & BLACK wires will go to the NEGATIVE side of the coil.
9. Let us know how it goes.
So I went to go look for one online and here is what I found with a quick google search:
http://www.streetrodstuff.com/Products/792/
MSD8202 Blaster II Coil $38.70
Does that sound correct and is that what I am looking to get? Do any of you guys happen to know the p/n from summit or jegs or something? I would like to go with a more "reputable" place.
Old Jun 27, 2003 | 10:45 AM
Engine: 346ci LS1
Transmission: MN6
TTT
I lost track of things with the headers post and the turbo thing going on, and then I thought that I still needed to find out this information.
Old Jun 27, 2003 | 11:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Put a dash between the "MSD" and the "8202" and that's the Summit number... and the price is NOT $38.70... not even close... that place you found is a ripoff! Look up all MSD part numbers though http://www.msdignition.com , slap a MSD- in front of the number, and look it up at Summit.
Old Jun 27, 2003 | 01:32 PM
Engine: 346ci LS1
Transmission: MN6
Well I headed over to MSD's website and I found a product that is called the Blaster GM Coil . I'm assuming this goes right in place of where the stock coil is currently.
The thing that also drew me away from the MSD-8202 was that it looked big (see picture)and I have no clue where to mount it with my A/C and such in the way. Also the MSD Blaster GM Coil looks more bolt-on.
MSD-8202 Blaster II Coil
Attached is my stock coil, correct me if I am wrong and that I could mount the 8202 in it's place....?
Attached Thumbnails FS: MSD 5a, MSD Blaster II Coil, Underdrive Pulleys-coil-002.jpg
Old Jun 27, 2003 | 01:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The 8226 is direct replacement.
That 8202 is a different charicter, and would require some major wiring, and mounting brackets made.
Old Jun 27, 2003 | 02:02 PM
So then do the 8226 and 8202 have the same spark specifications? I can't seem to find it on their website.
Old Jun 27, 2003 | 02:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dale, I didn't think the wiring that I posted (which WWasem dug up and quoted above) was major! And you can buy a bracket to hold the actual coil; any additional bracket to hold the special coil bracket to the car might have to be made; but hey, that's what Home Depot's hardware aisle (steel strip stock), a hammer, a vice, primer, and semi gloss black spray cans are for!
But it is a pain to mount a coil... look what I had to do below. Benefit is that I left my original coil in; if I die on the side of the road and suspect my ignition, i can plug the original GM coil back in and see what happens.
Attached Thumbnails FS: MSD 5a, MSD Blaster II Coil, Underdrive Pulleys-tomp-coil-all-views.jpg
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
