Coil and EGR bracket
Old Jun 12, 2003 | 07:30 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
How do I take this off? I believe I can get away w/ removing the valve covers w/o disassembling the plenum. This is the only thing in the way (besides the alternator and tensioner). I think I can get a wrench under the plenum to remove the valve covers.
Old Jun 12, 2003 | 07:33 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
it bolts to the exaust manifold, if you can get a socket or wrench up in there and break the bolts loose, you should be able to move it out of your way.
Or.... you could always just bend it out of the way like i did, and then bend it back in place. Its just a silly bracket, nothing important.
Old Jun 12, 2003 | 10:31 PM
KED85's Avatar
All bolts are 15mm.
Two bolts ontop on manifold.
IF ya figure out a way, good going.
You are a Valadictorian
But I tried and just removed the stuff.
I had cover loose, too.
It was teh driver side that screwed me over.
Loose, but no allow past the middle intake part to get off
PISSED
Took all of extra 15 minutes & reused original gaskets again.
NOT valve cover, of course.
Do ya know which is the noisy lifter?
Old Jun 13, 2003 | 12:30 AM
89V6FBIRD's Avatar
OK so I guess I'd have to soak those in PBlaster, because they're on the manifold. I don't know which lifter it is, but I know there's at least one on each side, so replacing my valve covers won't go to waste!
I think it just takes a bit of patience w/ an odd combination of sockets to get the valve covers off w/o removing the plenum. I think the biggest thing I'm afraid of is depressurizing the fuel system and breaking anything related to the fuel rail. Don't wanna touch that!
MM2Robinson
Oct 1, 2017 09:16 AM
Kenwood
Sep 11, 2015 12:50 PM
Jlanz55
Sep 6, 2015 03:05 PM
rjcme
Sep 5, 2015 01:23 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
