does this go to the starter?????????
Old Jun 14, 2003 | 10:27 AM
92 RS JD's Avatar
Im having problems with my car starting sometimes it just clicks i had a new starter put in and it still does it I pulled it out and had it tesated its good none the wires are loose. But there is a plug right above were the starter goes with a sensor does this go to starter the wire that pugs into it is broke .
Old Jun 14, 2003 | 11:03 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
no it doesn't have anything to do with the starter. I would check your starter relay and the like. How tight are all your battery cables?
Old Jun 14, 2003 | 03:44 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i had the same problem with my jeep and a friends datsun. remove your bat cables, clen heavaly with wire brush, put them back. reset your radio clock (damnit). problem should be solved
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
