Should i use the blue RTV stuff?
Old Jun 14, 2003 | 02:25 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys im changing all the gaskets in my MPFI intake and valve covers. Im going to port it and stuff and i wanted to know if i should use the Blue RTV stuff when im reassembling the intake. Thanks
Old Jun 14, 2003 | 02:35 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
what you should realy do, especially on intake, is get real gaskets i have even heard you can get a roll of gasket material and cut your own (tomp). if you do use rtv some extra may come off and get jammed some where. clogging your intake. all in all it should be worth your time/money to go with gasket set/own gaskets.
Old Jun 14, 2003 | 06:44 PM
I did get real gaskets. I got pretty much all the gaskets to rebuild the upper half of my engine (which is what im doing). And the intake is next to go on. I wanted to know if i should use a little rtv w/ the gasket like you would use with the valve cover gaskets.
P.s. The gaskets are not cork if that helps any
Old Jun 14, 2003 | 07:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Dont use it on the intake parts! If you want some extra sealing use Hylomar (aircraft sealant). It is just like silicone but wont dry out, just spread a paper thin layer of it on and you wont have any problems, even makes the gasket reuseable sometimes.
xbazzarex
Dec 1, 2015 05:25 PM
sreZ28
Oct 22, 2015 08:21 AM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Linson
Sep 21, 2015 01:08 PM
