I hope I don't get bombarded for asking a stupid question
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
a 3.1 is an example of a s"stroker motor." You take a "standard" engine and put a crank with a longer stroke in it. That's a stroker in a nutshell.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you idiot
I can't believe you stupid you are
don't know what a stroker motor is
ugh when will these kids ever learn
I mean come on.... stroker... duh
leave the boards and go somewhere else
ok so I'm just razzing you
but yeah a stroker is a motor with a longer stroke as someone else said
the 383 is a common stroker motor
takes the 4 inch bore of a standard 350 and a .030 overbore I think
gets rid of the standard 3.48 inch stroke in favor of a crank from a 400 Small block chevy which is 3.75 inches and puts that in there
so see you gain a .27 inches extra stroke
while overboring is taking some extra meat out of the cyl wall to make for a wider cyl
stroke is the throw of the crank
or from dead center on the crank to the middle of the arms that stick out
that distance is your stroke
hope that helps you a little
Ok, so this is kinda on topic for this thread...
Would stroking my 2.8 be worth it? (I've it outta the car and the pan sittin' off it, so putting the new crank on wouldn't take much more effort).
And secondly, how far can stroking go? Like you said, that one is 0.27" (+ 0.30 bore, but yeah) , how far can I take it in my 2.8, and what will it buy me over all?
Lastly, if I decide to do this, where can I find that crank (aka, can I take one outta a different engine from a junkyard, cos I'm on a VERY tight budget here)...
Thanks!
-Ray
Thanks!
-Ray
Car: 1988 Camaro RS
Axle/Gears: 3.42's
you know what you shoild do? Just go out to the junkyard and pickup a running 3.4L motor and shove it in there, it'll cost you about the same amount of money and you'll get a motor that already has A LOT more power. That's what I think would be worth it.
