The text on the dash
Old Jun 23, 2003 | 04:31 AM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
The text on the dash is not working, what is the problem ???
thanks
Joe
Old Jun 23, 2003 | 07:56 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Uh, what do you mean by the text on the dash?
Old Jun 23, 2003 | 07:57 AM
'88 Bird Owner's Avatar
I'm guessing you did this, but it's my guesses...
1) Check voltage going to it?
2) Check all wires, cables, etc?
My friend had a similar problem, turned out to be a fuse or somethin' silly like that...but hey, I might not even be answering the right question here
-Ray
Old Jun 24, 2003 | 03:31 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
Sorry about my poor English, the "text" means that the history miles recorded showed on the dash.
I am a Chinese in Taiwan.
Old Jun 24, 2003 | 05:44 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Joe is your speedometer working at all? If not, the plug could have come undone at the transmission, so check that out (if you have the electric speedometer).
Old Jun 24, 2003 | 07:03 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Good suggestion quick.
Also, to help better...
1. What year, and tranny?
2. Do the lights light up?
3. Does speedo needle work, but doesnt register miles?
4. All other guages work also, or no?
I belive were all willing to help ya, but since we speek different we have probs understanding each other. Let us know some of the above answers.
Old Jun 24, 2003 | 08:30 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
thanks a lot,
my speedometer work fine but the part I just mentioned, it is 1990 firebird v6 with auto tranny.
The all needles work, but it just doesn't record miles, what happen!! the people here don't know firebird well, so they want to take apart my donor car's speedometer to find out. (BTW, they put my donor car's speedometer on but still no improve, maybe they both broken or the problem is no on the speedometer! )
Pls help
Joe
Old Jun 24, 2003 | 08:35 AM
Dale's Avatar
Engine: 350 S-TPI
Ok, so you and I are having similer problems.
1990 is an electronic given speedo, no cable. So something in the cluster(s) is bad.
Mine will jump several miles, works fine, stop working, works fine, jumps miles, etc.
I have not went any futher then cussing it out.
Hopefully someone will have an answer for both of us.
Old Jun 24, 2003 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dale, is it you or WWasem that has the '90-'92 GM Service Manual? Maybe it has a diagnostic chart for the speedometer?
Wow... I found a lot of people with 1990 f-bodies with odometer problems:
https://www.thirdgen.org/techbb2/sho...er+not+working
Here's an interesting message: https://www.thirdgen.org/techbb2/sho...er+not+working
I can't find anything useful. A few messages said to take the old one apart and look for broken pieces to make "one" odometer out of two broken ones. Did you try eBay or (at top of screen) <a href="http://www.thirdgenresource.com">Third Gen Resource</a> or <a href="http://www.hawksthirdgenparts.com">Hawks' Third gen parts</a> ? Maybe they can be cheap on shipping?
Old Jun 24, 2003 | 10:39 AM
Dale's Avatar
Engine: 350 S-TPI
tomp, I got a 91 helms on the way
Old Jun 26, 2003 | 01:58 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Is the 88 an electronic speedo? Everything on mine works...except for the trip meter. The odometer reads fine, i just can't tell how long I've gone on a tank of gas unless i pay attention to the odometer everytime I fill up and then I have to do math...it makes my brain hurt.
Old Jun 26, 2003 | 06:37 AM
Dale's Avatar
Engine: 350 S-TPI
88,
I'm not sure if its elec, or cable. But if your miles works fine, and trip doesnt. That means something inside is bad and needs rebuilt if possible, or replaced.
Vintageracer
Sep 24, 2017 12:34 PM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
