Coolant sensor on a 3.1 v6
Old Jun 25, 2003 | 09:11 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Can someone post a picture of where to find this puppy, I believe this is my culprit for my high idle.
Old Jun 26, 2003 | 12:03 AM
pasky's Avatar
Wow, nobody?
Old Jun 26, 2003 | 01:16 AM
pasky's Avatar
Ok, can someone just circle the general area?
Old Jun 26, 2003 | 06:35 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You have two sensors.
The circle up by the intake is the ECT that goes to the ecm.
The circle buy the ac pump. Sensor is behind it, goes to your guage cluster.
Old Jun 26, 2003 | 01:32 PM
pasky's Avatar
Thanks, now which one is the one that would effect the car into staying into a high idle, I would think its the first correct?
Old Jun 26, 2003 | 03:28 PM
Dale's Avatar
Engine: 350 S-TPI
Dunno about high idle, but first one will cause SES light. 2nd one just effects the cluster guage.
Old Jun 27, 2003 | 06:48 AM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
sensor
Yep, the sensor is right under your TB and next to the thermostat housing. It plugs into the same harness as the injectors do. A new one costs about 9 bucks at Autozone. you can use a 3/4 deep well socket to remove it without taking anything else off the car.
good luck
Old Jun 27, 2003 | 09:08 AM
Dale's Avatar
Engine: 350 S-TPI
mine was 19mm, but figures up to .75 :sillylol:
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
cking99
Sep 22, 2015 11:33 AM
BWilcox
Sep 20, 2015 12:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
