Help Me!!!
Old Jul 1, 2003 | 08:17 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
Help Me!!!
today i tried to change my waterpump but it took me 3 hours
and it still isnt changed... there is this stupid mounting bracket for the powersteering that wont come off and there are 2 bolts behind the pully i cant get out because the pulley is blocking it... there is no way to take the pulley off ... what the hell am i supposed to do ?
Old Jul 1, 2003 | 10:20 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
why can't u get the pulley off?
All I had to do and all you should need to do is take the bolts out of the pulley and if the pulley still doesn't want to move introduce him to Mr. Rubber Mallet. Don't kill the thing, but i nice whack did the trick for me.
I don't know about the power steering as when I replaced my water pump, the engine was out and the PS wasn't still bolted on
Old Jul 2, 2003 | 01:22 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
the pulley dosnt have anybolts to take off
Old Jul 2, 2003 | 03:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Why are you taking the pulley off the power steering pump? Take the whole power steering pump, including the bracket, off of the car. Should be a 7mm bolt holding the bracket to the front of the water pump, and I think the other bolts holding the p/s bracket to the engine are 13mm in the front, 15mm in the back.
There's no need to pull the p/s pump pulley. To do so, you need a p/s pump puller/installer set, like this one:
<img src="http://www.tptoolbox.com/Database/KD/2897.jpg">
That's from http://www.toolparadise.com , type in "power steering puller" into the search box on the RIGHT, and click "GO". But don't make extra work or spend extra cash for something that you don't need to do... like Damien said, he changed the water pump when the power steering was completely off the car.
I hope I explained it right... leave the bracket connected to the p/s pump, but unbolt the bracket from the engine.
Old Jul 2, 2003 | 09:05 PM
I was thinking you needed help getting the water pump pulley off...hence the bolt thing
Old Jul 3, 2003 | 12:01 AM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
i got it off with the puller tom talked about above .... thanx tom
today i put the waterpump on and changed the thermostat with a hypertech 160. tomarrow i will do a tb bypass and put the hoses on and fill up the radiator with antifreeze
