Fuel Pump Fuse
Old Jul 5, 2003 | 02:16 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
Fuel Pump Fuse
WHERE IS THE FUEL PUMP FUSE ON MY 86 2.8 FIREBIRD???????
Old Jul 5, 2003 | 06:35 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
dude, don't feel bad 'cause you can't find it. I was told that it was one of the fuses mounted up on the firewall next to the brake booster, but I pulled all 3 of them and the stupid thing still ran...so I don't know either.
Old Jul 5, 2003 | 07:30 PM
Engine: 2800
RIGHT, well my car won't run, so i need to find it, i think im having a problem in there, she cranks away and won't start, so i'm havin to know where she is!!!
Old Jul 5, 2003 | 08:57 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
are you sure it's a fuel problem. Most of the time when a car won't start, it's ignition. I don't know how much you have looked into the problem, but it's worth a try. Does the pump buzz when you turn the ignition to "on" but don't start it?
Old Jul 5, 2003 | 11:03 PM
Engine: 2800
i think ive tryed pretty much everything with the ignition, im just running thru the options... but till, would be nice to know where that fuse is anyways.... and yes.... i belive there is a buzz
Old Jul 5, 2003 | 11:17 PM
socialdeviant's Avatar
did you look on passanger side fender beside the headlights?
there should be a 3 way post relay, the wire that goes back to the firewall will have a fuse holder in series with a weatherpack top, pull cap, fuse is right there.
Old Jul 5, 2003 | 11:21 PM
Engine: 2800
thought that was the maf and head light fuses... but yeah, ill check that out
Old Jul 6, 2003 | 01:48 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
The 3 plugs you see on the driverside firewall are the relays, and yes one of them is the fuel pump relay. As for the fuel pump/ECM fuse (thier one and the same). Its near your engine coolant reservoir, should be on the passenger fender. You'll know its it because it has a electrical plug, the fuse is hooked on the plug. Well, thats where it is on my 3.1, might be the same for the 2.8.
Old Jul 7, 2003 | 09:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yes, it's in the same spot on the 2.8. 2.8 will also have a MAF fuse nearby. MAF fuse uses red and brown wires to the fuse holder. ECM/Fuel pump fuse has red and Orange wires coming from it.
Check the circuit (CKT 340) with a test light at the fuel pump relay to make sure you're getting +12 volts.
Old Jul 7, 2003 | 04:05 PM
Engine: 2800
ok found it, i thougth that the fuel pump fuse was one of the head lamp fuses, but i guess not....
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
