Trouble codes while driving
Old Jul 7, 2003 | 06:44 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I read in another post previously about being able to tell if your car is running rich or lean while driving by having the 6 and 12 pins connected while driving.
I'm wondering if this is correct. And I would like to know if I'm supposed to jumper the two pins before starting the car or after the car is already started.
Thanks in advance.
Old Jul 7, 2003 | 10:54 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Partially right...connect the A and B terminals just like you were going to check for Check Engine codes... A and B are the two furthest to the right terminals on the top row.
Connect the two with the car off and then start it. Don't connect them while the car is started. If I remember correctly, Even between Check Engine light on and Check Engine light off means you're running normal. If the light stays on more than it stays off, then it's rich...and if it's less light and more of no light, then lean. I THINK!
gta90
Sep 15, 2015 04:00 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
