Specs for the new 3.5L OHV
Old Jul 13, 2003 | 06:41 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
NOTE: I got this info from 60degreev6.com
Type: 3.5L V-6 (LX9)
Displacement: 3498cc (213ci)
Compression ratio: 9.8:1
Valve configuration: overhead valves (2 valves per cylinder)
Assembly site: Ramos Arizpe, Mexico
Valve lifters: hydraulic roller
Firing order: 1 - 2 - 3 - 4 - 5 - 6
Bore x stroke: 94 x 84mm
Fuel system: sequential fuel injection
Horsepower: 200 @ 5200 rpm
Torque (lb-ft): 220 @ 4400 rpm
Fuel shut off: 6000 rpm
Emissions controls: evaporative system
catalytic converter
exhaust gas recirculation
positive crankcase ventilation
Application: Chevrolet Malibu
Block: cast iron
Cylinder head: aluminum
Intake manifold: cast aluminum
Exhaust manifold: high silicon molybdenum
cast nodular iron
Main bearing caps: powder metal (1,2,3)
cast iron (4)
Crankshaft: steel
Camshaft: assembled steel
Connecting rods: forged powder metal
Additional features: extended life spark plugs
extended life coolant
Oil Life System
Old Jul 13, 2003 | 08:59 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
will the block be able to accept conventional motor mounts?
or only FWD dogbones?
also, you will have to grind away some of you tranny considering the starter is on the opposite side
Old Jul 13, 2003 | 09:42 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
you could probably make your own motor mounts/plate thing.
thats the only info i have on it so far... i dont even know if the blocks are the "same" as the 2.8/3.1/3.4, i just know that its a 60degree.
Old Jul 13, 2003 | 10:05 PM
KED85's Avatar
The engine is coming in RWD also.
I believe I saw the 3.5 or 3.6 (not sure exactly I've read diff "numbers") in action when I saw the 2005 Caddy STS roadtesting in Van Nuys, CA the other week.
See AUTOWEEK July 7th issue for the full story of what I sighted.
Old Jul 14, 2003 | 08:20 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
the 3.5 and the 3.6 are different, there will be BOTH a 3.5 and a 3.6L 60degree V6.
The 3.5 is not DOHC or anything, its a single cam pushrod. (like the 2.8L)
The 3.6 is supposed to be DOHC.
Old Jul 14, 2003 | 09:10 AM
KED85's Avatar
I know the one I saw was a 3.6 & that follows with what I've read in Hot Rod, Car Craft.
The Autoweek article I read after I spied the 2005 Caddy STS being roadtested said it's powered by the 3.6.
IF I'm correct in my assumption (I've only seen one pic) the 3rd Gen & 4th Gen headers from PaceSetter will also fit those 60* mills, too.
The new 60* mill pic I've seen was in Car Craft & that front timing chain cover sure looks identical to the engines of our 3rd Gen rides.
Kinda gives me hope now that when my 3.4 one day dies, I can go to a wrecking yard & just upgrade by a used low milage long block again.
Old Jul 15, 2003 | 07:26 AM
NHRATA01's Avatar
I thought the 3.6 was that fancy "high feature" deal with the twin in block cams with 24 pushrods working 24 valves?
Old Jul 15, 2003 | 07:32 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
The 3.6L is a DOHC 24 valve 60 degree V6--not a pushrod. Nothing in common with the OHV 3500.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
