Almost there....again.........
Old Jul 13, 2003 | 11:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I have the t-pipe back on, wrestling w/the convertor. Doesn't want to go over the end of the t- pipe. Gonna take it to AZ & see if tail pipe expander will push it ou t just a touch. THen drive it to the auto hobby shop & put the dynomax on. Should sound awesome driving it w/just open convertor :rockon: Gotta use the 30 day tags while I can
Old Jul 14, 2003 | 01:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have one of those tailpipe expanders; used it on my Megs tips to expand that 2" inlet into a 2.5" inlet. Worked pretty good too... it was the less expensive $25 one from Lisle. I think they make a $40 one that has a wider range of motion, too.
Old Jul 14, 2003 | 11:27 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I don't mean to try to hijack the topic...but...pipe EXPANDERS? Wow.....how in the crap do those work? I just can't visualize...
Old Jul 15, 2003 | 12:01 AM
Engine: 5.7 / 7.4
yup, it stretches out the end of the pipe to make it just that much bigger. Just shove it up the pipe opening, and use an impact wrench to tighten'stretch. I just need a little due to the "physicality" of removing the stock rust cat . New cat is installed, along w/new battery :lala: :lala: :lala:
Should have cat-bak in by friday
Old Jul 17, 2003 | 01:11 PM
Engine: 5.7 / 7.4
OK, cat is on and will going tothe auto hobby shop friday night & finish the exhasut. Also got the overhead console, finally, in the mail. I t looks a lot bigger in the e-bay pics. Only one main problem w/it.....the flashlight has "camaro" on it
Question for those who have this item: the wiring for the dome light on/off switch, there is a white white wire...what does this go to/get conected to? There is a black & red wire, I figured those connections easi;y, but the white wire is a to me.
Old Jul 17, 2003 | 01:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did you really pay $100+ for one of them overhead console???
I see a 10 year old one for for $95, and another used one for $120.
It does not seam worth it for what little you get.
Matt
Old Jul 17, 2003 | 01:41 PM
Engine: 5.7 / 7.4
I actually won it for like $62 + $10 or so shipping. I was surprised also it went for so little also
Old Jul 17, 2003 | 02:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I will make sure and look for them suckers. Doesnt JCwhitney make ones like that???
They are "universal" but geese. a 10 year old used part for any thirdgen should not be that much.
I am sure its nice as the center counsol fills up quick. I got about 90lbs of chage in mine. and Only thing that will stay in my dash pocket is the stock owners manual.
Matt
Old Jul 17, 2003 | 02:08 PM
Engine: 5.7 / 7.4
it's not really meant for "functional" use. per say. it does have a domelight in the back for the nether regions, a swivel single dome for the font, a very useful flashlight (that otherwise would take up space in the cemter console or get lost anywhere else), and some very "high tech" numbers/word things to keep track of appts/gas millage, etc. that parts a novelty, but then, how cars do have this option???
