2.8 V6 engine running bad
Old Jul 14, 2003 | 04:57 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Have an 82 Pontiac Firebird 2.8L with 200c Transmission. I am having problems with the engine. The engine seems to lack power and when driving along sometimes if I slow down and then start to speed up the car starts to shudder during acceleration. The Idle speed adjust solenoid (beside carburetor that pushes the throttle) sometimes comes on and stays on. There is excessive oil leaking from the rear main seal. I have done a compression test on the engine and that is fine, checked the PCV system, replaced distributor, distributor cap, plug leads and plugs but didn't help much. I put in a new fuel pump before Christmas. I don't know what else to check for. Anyone got any suggestions as to what I should do next.
Any help greatly appreciated,
Gerry Holian
Pontiac Firebird 2.8L V6
Old Jul 14, 2003 | 10:47 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
During the shuddering, what are your rpms at? Maybe the transmission isn't kicking down/downshifting properly? Wish I could offer more technical advice, but your car is way out of my expertise...I don't know carbs, and I don't know ANYTHING about the 200C tranny.
Old Jul 14, 2003 | 11:49 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could be shaft seals in the carb.
82-85ish were not good years for the 2.8 over all.
Id pawn it off on the first "sucker"
with enough cash and buy an 86+
Matt
Old Jul 14, 2003 | 12:19 PM
F585's Avatar
Matt
What's wrong with an 85 2.8? I thought 85-86 are identical.
usafirebird
Sep 29, 2015 11:58 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
89bird2.8
Sep 18, 2015 07:46 PM
snakeshooter
Sep 7, 2015 11:13 AM
