3.4L Manul trans swap into a 3.1
Old Jul 30, 2003 | 09:30 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i need to know if a 3.4l firebird manual transmision will swap into a 3.1 liter camaro. if so will i need anything special to do so? i need to know soon so the trans doesnt run away before i get to it!
Old Aug 5, 2003 | 05:27 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If it's a manual trans you shouldn't have too many problems considering the fact that you are controlling the shift points and not the computer. As for mounting dimensions, I'm not positive, but I believe it's pretty straightforward.
Old Aug 5, 2003 | 06:26 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You will need a clutch for the 3.4l, not the 3.1l. Front splines are different requiring this.
the 3.4 shifter hole is about .5-.75" futher back then the hole for a 3.1.
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
the_nikfive
Aug 11, 2015 02:46 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
