Diffrence from Cammy and Birds IAC sensor?
Old Aug 2, 2003 | 01:02 AM
maverick544's Avatar
I picked up a lil IAC sensor from teh junk yard off a Camaro with a 2.8L I Think. Is there any diffrence in thats sensor on all the Fuel inj. f-bodies? Cause I got a 89 2.8L Firebird.
Old Aug 3, 2003 | 01:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nope, not between 2.8's. 3.1 IAC's attached differently to the throttle body. You should be all set.
Old Aug 3, 2003 | 03:06 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Tom, Do you know if the top TB plate on the 3.1 will interchange with the 2.8 TB's. I am interested to see if there is more clearance with the IAC with the 3.1 upper TB plate on my new plenium design? Basically, do you know if it sticks up or out at a different angle than the 2.8 IAC?
Thanks, Dean
Old Aug 3, 2003 | 03:18 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Thanks, Dean
Here's a pic showing where I have grinded too much and had to build back the area with weld beads
Old Aug 3, 2003 | 05:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
AGood2.8, the 3.1l TB IAC comes straight out toward the passenger side. It is on top of the TB with the TPS directly below it. The IAC is a different design as it has a flanged mount with two screws to fasten it to the TB.
I can post a pic of the factory diagram if it helps.
RBob.
Old Aug 3, 2003 | 07:32 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
RBob.
Thanks Rob for the info. I have an aquintance that has a 3.1 Camaro that I can check out in person (thankyou for the picture offer- but no need) I have seen his engine before, but never realized that the IAC was different when I glanced at it years back.
I"ll check that out, see if it will work better.
Dean
Old Aug 4, 2003 | 01:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks, Dean
Yeah, sorry, I don't know much about the 3.1's... never seen one in person, -or- in a junkyard. I'd think that the 3.1 might integrate into your design better since it would only require drilling/tapping two small mounting holes and drilling a center hole. It might "intrude" less into the throttle body.
And I'm sure you might even be able to somehow weld up studs that stuck out of the TB's side instead of drilling holes to insert screws for.
92firebirdguy
Sep 1, 2016 07:53 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 2, 2015 03:39 PM
