Results from E-Check Nazis......
Old Aug 2, 2003 | 12:25 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Results from E-Check *****......
Tampering:
Cat Convertor.........................Present
Presence of gas cap................Pass
Emissions:.............Reading................Limit............Result
HC.........................718.9.....................157............Fail
CO.........................13.34......................1...............Fail
CO2........................6.32........................................N/A
Gas cap passed pressure check.
This is w/the MSD Box. During the test, done around 25mph, black smoke going out of the tail pipes . I still have to change erl, erl filter,plugs. I'm going to see about connecting the )2 sensor wire to the one in the T-pipe & see if that all makes any differenc.
BTW, Got the title today :lala: :lala:
Old Aug 2, 2003 | 05:15 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
why did you even try to get it tested with black smoke comming out the tailpipe? :sillylol:
Old Aug 2, 2003 | 10:06 PM
Engine: 5.7 / 7.4
Didn't know it was spwewing out. BEsides, gives me a baseline to tune, and still gotta figure out this running rich problem. I cleaned up my plugs, they were new, all of them covered in black soot.TPS is good, but now the fuel pump isn't running Another thing to troubleshoot
Old Aug 2, 2003 | 11:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
those darn e-checks are such a waste of money. i had to fork over 40 bucks cuz my RS and Beretta were both due. emissions sucks lol
edit:whoops... This is Erin91RS. i'm on my b/f's screen name.
Old Aug 4, 2003 | 10:21 AM
devianb's Avatar
I'm a bit concerned about e checks when I move becuase I will most likely end up in a city with e checks.
What happens if you fail repeatidly?
Old Aug 4, 2003 | 10:22 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
most of the time if you prove you have spent over 400$ to try and fix the problem, they will pass you.
Old Aug 4, 2003 | 11:26 AM
Engine: 5.7 / 7.4
Well, some of the Accel wires got toasted fromthe fire, they're getting replaced tonight or tomarrow. I'm also going to see about a "mod" to the egr& see if it'll help clean up the intake charge.
AS far as the fuel pump goes, I just plugged the harness to the a/c relay & it runs as good as it has so far.
Old Aug 4, 2003 | 03:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Fire? What happened?
And yeah, definately seems like a misfire -and- running rich, see this for more info: https://www.thirdgen.org/techbb2/sho...hreadid=193670
Old Aug 4, 2003 | 08:34 PM
BitchinRS's Avatar
If you are pumping enough unburnt fuel into the exhuast you may have destroyed your cat. If you still fail after you fix you major miss fire problem replace the cat.
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
