still battling problems
Old Aug 10, 2003 | 09:07 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
i was told that my fuel pump is too loud when it primes, it is sucking air, and that my problems~> starting, starting and dying, no start, surging shifts, are from the pump that is going. is this true? i still think i have a problem some where in my ignition, just wanted to see what you guys thought
Old Aug 10, 2003 | 10:02 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if the fuel pump is sucking air, then do you have any gas in the tank?????????? have a f/p gauge available?
Old Aug 10, 2003 | 10:26 PM
Engine: 2800
3/4 of a tank in there man,no fuel pressure gage, but have had it tested, and told it was fine, the guy that told me about all this stuff is a friend, and is a really good mechanic, and when he heard that pump, he said, naw thats not right, should't be that loud, then proceded to explain the process to me, so.... i don't know, i just want my car to run!!!!
Old Aug 10, 2003 | 10:32 PM
Engine: 5.7 / 7.4
Have you heard the fp before? The first time I didn't hear mine I knew something was up.
Old Aug 10, 2003 | 10:34 PM
Engine: 2800
heard the fuel pressure? when the pump primes its a distict buzz from the back of the car, last's 2 seconds or so, thats what this guy was talking about
Old Aug 11, 2003 | 12:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats normal because of where the fuel tank is. Most cars you only hear the buzz from outside but the thirdgens have the gas tank right under the hatch area. So you hear it inside the car more than out.
Matt
Old Aug 11, 2003 | 06:10 AM
Engine: 2800
no, you hear this inside outside and all over, i just want to be sure because changing the pump in this car will be a project.....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
