v6's and t-tops!!
Old Aug 18, 2003 | 06:41 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
v6's and t-tops!!
Did and v6 birds come with the t-tops from the factory??
i think i may get a 80ish bird and was curious and from the search it seems that some people have it but only in the 3.1 or 3.4 and not factory??
also will a v6 feul sender work in my 5.0 TBI??
thanx!!
Old Aug 18, 2003 | 08:37 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yes, t-tops available on all 6cyl models. maybe even the 4cyls too
TBI? ok,
the sender should work on the f-body, it's based on an ohm reading range.
edit: like the gauges, but what's up w/a 120 sppedo? 85 is where it's at
Old Aug 18, 2003 | 11:25 AM
TransAmTBI's Avatar
Engine: 305 TBI
85??? you must be kidding lol i love my 120 speedo by the way the guages are from my TBI... the 6 cylinder i may get will be a daily driver while i put my new heads on this car! so i may need you guys for all my v6 needs! but thanx to you i'll be able to read my gas again with the v6 sender in my car
Old Aug 18, 2003 | 11:18 PM
Engine: 5.7 / 7.4
yeah 85. That way, when the car running the way it should, I could technically burry the spedo @ the track on a stock engine
Old Aug 19, 2003 | 10:52 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
You guys need to get ahold of that 140mph v6 speedo!
Old Aug 20, 2003 | 12:31 AM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
where do you get the 140mph speedo?????
Old Aug 20, 2003 | 04:10 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i've got a 140 mph speedo...wasn't for a v6 but'll work, prob is i've gotta do a guage conversion to use it, cause i've got the ole' mechanical unit...but getting something like that for free makes whatever mods needed more than worth the time and energy, plus it'll be nice when start the Ls1 swap.
Old Aug 20, 2003 | 04:25 PM
Orinackra's Avatar
Somebody on here had a white face one, I think he made it himself. I got my hands on a copy, and switched it over to black. I honestly can't remember his name.
Edit.. found the thread, go here:
https://www.thirdgen.org/techbb2/sho...hreadid=193244
Old Aug 21, 2003 | 12:23 AM
fbird89's Avatar
Car: 1989 Firebird RIP, 1979 Formula RIP
Engine: 5.7L L82 350
The 89 Turbo TransAm had a V6- what was the speedo on that?
Old Aug 21, 2003 | 11:02 AM
Orinackra's Avatar
Thats a good question, my best guess would be that since it is a trans am, it would have a properly calibrated v8 speedo. I could be wrong though.
Old Aug 21, 2003 | 12:01 PM
85f-bird's Avatar
Engine: 2.8L, LS1
more likely than not it also had the 140mph speedo, just a thought....since all of the cars since then would have been electric speedos, all they would have to do is get the VSS from the tranny, and boom, in business.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
