I thought it was the maf .. but it cant be
Old Aug 20, 2003 | 11:04 AM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys I just took the bird out for a spin to go order a MAF relay from napa and she had hesitation starting from a stop until she got warmed up then she had absolutely none and was running really nice. What would make her do this? The maf sensor was unplugged
Old Aug 20, 2003 | 11:54 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
When the MAF is unplugged, the computer uses a preset to substitute for the the lack of MAF input. THis is why a car will still run w/it unplugged, but not as good as it could.
Old Aug 20, 2003 | 03:25 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
when i unplug my MAF, after the car reaches its running temp AND passes 5 mins, it shuts off
The haynes manual says that the ECM will not start reading the MAF sensor until the engine has reached operating temp AND passes 5 mins of running time, which explains why my engine cuts out when it heats up. The MAF reads how much air is going into the engine, and then the computer tells the injectors for how long to pulse, thus if the MAF is unplugged, the computer thinks no air is going to the engine, thus not firing the injectors, thus the engine stalls.
Old Aug 20, 2003 | 10:34 PM
funstick's Avatar
the ecm reads the maf sensor every microsecond the ecm sees power from the key FYI. haynes is wrong.
Old Aug 20, 2003 | 11:34 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well i had a bad MAf a little while ago, the cars idle was crappy, acceleration not to good, etc etc etc. Once when the car was warm i had unplugged the MAF meter, and drove the car for a while, and the car ran ok w the sensor unplugged, so i don't know why yours turns off lee, i've never had that problem.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZ1989
Sep 4, 2015 11:54 AM
