fuel pump????
Old Aug 22, 2003 | 04:22 PM
ionicswing's Avatar
fuel pump????
my car pooped out today....i think its the feul pump, motor still turns, but seems as if no gas is gettin there. the tank has 1/4, any intrustructions on how to replace the fuel pump, or any other ideas of what ever else may be the problem would be appriciated.
Old Aug 22, 2003 | 05:45 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
fuel pumps can be a bitch, easiest way to see if it's the pump is to turn the car on and listen to hear the pump prime, that's to the on position and not started....also don't try it after that cars been running for a while, cause it might not prime anyway, since the motors already hot. Also, did u add any gas right before the crap out? bad gas can give your car the same effect, tons of cranking, lots of spark, but no startin....hope it'd be the latter....fuel pumps require dropping the exhaust, rear axel, and then the tank to get to it....another way is to cut a hole in the rear of the car, remove the carpet, cut the hole, you can reach down and grabthe pump from there, replace it, and then put a panel over the hole (could get a round piece of metal and screw it down for future replacement, that's the easiest way to get to it...others on the board however have actually done it, and they'll fill you in on more info if you need it.
Old Aug 22, 2003 | 07:55 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Spend teh $35 for a fuel pressure tester. A VERY WISE investment. Then do the pressure checks. Not only good for your car, but any others you mightget/friends cars & whatnot.
Old Aug 22, 2003 | 08:38 PM
ionicswing's Avatar
k........i got it towed back to me house.........and, it does seem to prime.....so im thinkin maybe fuel filter clogged??....and where is the fuel filter located??
Old Aug 22, 2003 | 10:03 PM
SYM Rule's Avatar
cant really miss it. It is by the rear drivers side wheel, but in front of it, not behind it.
Man, did that make any sense?
Old Aug 23, 2003 | 12:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree 100% with Project '85- buy the fuel pressure gauge and diagnose the fuel pump the -real- way.
Then buy the Haynes 82-92 Firebird or 82-92 Camaro book ($15) for the procedure on dropping the gas tank.
Old Aug 23, 2003 | 06:18 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I've similar problem with gas. I bought a chinese/taiwanese/korean, or etc. fuel presure tester for $9.70 (equivalent) and I did the test. Fuel presure was @ 40 PSI exactly, then I suspect a clogged fuel filter (VOLUME problem, no presure problem). I'll replace it and will check the new performance.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
